TB/Plenum/CAI worth it?
The Accufab unit looks really nice. I have the 75mm throttle body/plenum combo. I could feel more pull in the midrange and on top end. You get what you pay for, but the difference in reality is a few hp at the wheels at best.
In your sig, you say you already have a K&N filter w/ removed silencer. That should cover your CAI needs, unless you want some more show under the hood.
ORIGINAL: 99GTvert
ORIGINAL: Prodigy17
Do you have CAI?
ORIGINAL: 99GTvert
ORIGINAL: Prodigy17
And did you instal your TB and plenum yourself? And did you notice significant difference after you installed it.........like worth what you paid?
I noticed the sound of air whooshing into the intake was much greater, and almost sounded like a turbo.
Throttle response was much more precise, and like I said before, I felt more power starting from about 2k up to redline. As far as price, I wasn't going to settle for less because I wanted the best. I felt that it was expensive, but I think I would have bought it eventually anyway.
Is your car a stick or auto? There is an issue with some units that people have reported the rpms hanging, and especially with an auto, that means longer stopping distances and just a pain in the *** when driving. I'm not sure if getting dyno tuned could help it out.
i have the same conbo, but i have the 70mm instead of 75mm. i had mine installed by someone cause im a retard, but also had it dyno tuned at the same time and picked up around 7rwhp. u could easily install it yourself tho.
