Mach 1000 problem.......
Ok ill get straight too it.
It has NEVER given me a problem until yesterday. I was not inserting or taking a CD out. I had not even touched the raido.
But i turned on my car and noticed it read CD ERROR. My radio worked fine but as i tried to listen to a CD it gave me the CD ERROR.
You know how when your 6 disc is switching between CDs you can hear it working? I dont even hear it anymore. Waht could it be? Could it have randomly went out?
If i disconnected the battery for a bit could it reset it?
My car only has 40k miles so its not like it has been used an awfull lot....
ORIGINAL: sxynerd
Here's a link that will explain your problem....
https://mustangforums.com/forumid_34/tt.htm
It was Just a thought. Unplug you Bat for a few minutes, it's worth a try. Amount of miles on a car doesn't mean crap anymore when it comes to electronics. Either your luck or your not. Good luck...
ORIGINAL: sxynerd
Check to see if a CD is lodged inside. If your lucky your CD door should be open and you should be able to see a CD kind of stuck in there. It's happened to me plenty times and had to use another CD to encourage it to come out. If not then time for a new system.
breaking
Oct 2, 2015 01:27 PM
So i went outside and disconnected my batery for a few minutes and then reconnected it and its working jsut fine!
