I dont know what I have
MyDad and I purchased my first cara 2000 mustang gt from a dealer. The dealer only said the factory radio was changed. My dad looks under the hood and sees a cold air kit and notices it doesnt have the stock pony throttle body theres also an h pipe installed.Car was bought for 9,400 , We also noticed the car has a whole different suspension and lowered.My dad said this car pulls alot harder than his stock 04 gt. How would i know if I have gears , upgraded clutch , tune , ect..
He means jack up the rear and spin the drive shaft and count the rotation of the wheels. If it takes 3.27 spins of the drive shaft than you have stock gears... 4.10 rotations than 4.10s ect.
Try to search for a few of your question on here... They come up all the time.
As far as the upgraded clutch goes, you will have to pull the tranny to find that out.
Good luck and welcome to the forums.
5 speed? if so then just compare the rpms to ur dads car. i think when im in forth doun 50mph im at like 2700? i forget but anyway just tell ur dad to see what rpm he is at in a cetain gear then get urs in that gear and see where ur at also, if ur rpms are higher then u probly have gears
ORIGINAL: 02StangGuy
A 45 car will tach about the same at 70 MPH with 3.73s as a 3650 car will wtih 4.10s.
