Redline?
Old Dec 7, 2007 | 04:43 AM
Sunadaime's Avatar
Sunadaime
Default Redline?
Is there anyway to raise it up to about 7000?
Old Dec 7, 2007 | 05:30 AM
scfd524's Avatar
scfd524
Default RE: Redline?
You could probably do it with a tuner bu why do you want to do that? Do you think you'll gain that much with the higher risk of damage to your engine?
Old Dec 7, 2007 | 06:05 AM
True Blue Racing's Avatar
True Blue Racing
you can remove your rev-limiter with a tuner, and then you can make redline as high as you want.
Old Dec 7, 2007 | 06:11 AM
SINISTER's Avatar
SINISTER
You do that with a stock motor and you are going to break something that is not easy to fix.
Old Dec 7, 2007 | 06:13 AM
Sunadaime's Avatar
Sunadaime
like i want to raise my redline up but... enhance my block to handle it? Idk really i love my stang i just want a bit more space between my shifts. Also i heard that putting a stage 1 cam increases the powerband to like 6500+
Old Dec 7, 2007 | 06:16 AM
True Blue Racing
yeah but you need a bottom end that will handle going into those higher RPsS
Old Dec 7, 2007 | 06:19 AM
Sunadaime's Avatar
Sunadaime
i know the later cobras have a 7rl but does the machs? theyre the same engine just with out the s/c huh?
Old Dec 7, 2007 | 06:42 AM
True Blue Racing
I was under that sameimpression. What do you drive?
Old Dec 7, 2007 | 07:04 AM
Ryan86272's Avatar
Ryan86272
ORIGINAL: Sunadaime
You can raise your redline to what ever you want...... [ol][*]Your Bottom End Will not handle it(Blown Motor)[*]You wont make any power past 5800-6k ( so why raise it)[*]If you get heads and Cams you will now make power to 6500+(Again Bottom End Wont Take it) Blown Motor![*] The 03 Cobras have a Built Motor THe Mach 1's Dont have a built motor. [/ol]
Sunadaime's Avatar
Sunadaime
i have a 97 gt with minor stuff. theres some stuff which was done before i got it. bought it off a stealership with no way to get ahold of the guy before me. It has about 130000 on it so i was just looking for a new engine and tranny to drop in it. Looking at 4v. but itll be awhile before i get that money XD so i wanna continue on with this engine
