sct chip
Old Dec 25, 2007 | 08:21 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default sct chip
http://www.americanmuscle.com/sct-4-...uter-chip.html
this chip holds 4 tunes right? and how do i install it and how hard is it to setup switched to flip between tunes? i mean....im going to get a 93 octane max gains tune and always use it, i never plan to use an economy tune....but i would like a valet mode.... someone just explain how this thing works please or if i would be better off with an xcal
Old Dec 25, 2007 | 10:40 PM
Sxynerd's Avatar
Sxynerd
Default RE: sct chip
You can get everything you need from AM. And they come with instructions. When you take out Your ECU make sure you clean all your coppers. If you don't have Chip board acid cleaner then use a pencil eraser to erase all the dirties off the copper connections. All and all it should take you about an hour to clean and mount everything.
Old Dec 26, 2007 | 03:07 AM
99BlackPonyGT
is a chip just as good as a handheld? and how do i switch between tunes? does the switch come with it also from AM?
Old Dec 26, 2007 | 08:24 AM
ripped camel's Avatar
ripped camel
Personally I like the programmer better. I had a Superchips chip on my Focus ZX3 a few years ago. I didn't like the fact that I had to mess with the computer board in order to mount it. It said right on the directions that it's possible to screw up the board. Luckily I was fine, but in my opinion a programmer is much safer.
Don't get me wrong a chip might save you money, and is perfectly safe if you install it right. But I think I'll always opt for the programmer from this point out as long as it's available for whatever car I own.
Old Dec 26, 2007 | 10:44 AM
Ryan86272's Avatar
Ryan86272
Programmers are Great and all. But i want a SCT Chip also...
With the Chip i can have:
17psi and 100shot Tune- Track Days
17PSI Blower only- Track Days
10psi Tune (Daily Driving)
1TUFF302
Nov 5, 2015 04:02 PM
12bigredstang
Sep 24, 2015 05:46 PM
12bigredstang
Sep 24, 2015 10:43 AM
03blackwidow
Sep 20, 2015 02:36 PM
kmad61
Tuner Central
Sep 18, 2015 05:02 PM
