power pipe?
Old Dec 31, 2007 | 12:11 PM
1fast 99gt's Avatar
1fast 99gt
Default power pipe?
do power pipes really help alot with a vortech? i want to get around 11 psi. i also have a 3.48 pulley. i am n/i.
Old Dec 31, 2007 | 01:01 PM
97stanger's Avatar
97stanger
Default RE: power pipe?
if im not mistaken the general theory is for every 1 psi you can expect 10rwhp. so say a powerpipe gives you 2-3 more psi your looking at another 20-30rwhp gain. not bad for $200+a retune if you ask me.
Old Dec 31, 2007 | 01:47 PM
Sxynerd's Avatar
Sxynerd
Is a Power Pipe the front tube that goes from the MAF to the S/C? The front tube in your sig 97Stang?
Old Dec 31, 2007 | 02:09 PM
1fast 99gt's Avatar
1fast 99gt
yes thats it.
Old Dec 31, 2007 | 02:17 PM
jEEd's Avatar
jEEd
I ♥ Acer
yeah they are really worth it after you get it tuned :] same with an IC
Old Dec 31, 2007 | 02:23 PM
Sxynerd's Avatar
Sxynerd
How does that pipe create more boost?
Old Dec 31, 2007 | 03:25 PM
97stanger's Avatar
97stanger
yep thats the power pipe, in a stock kit you get a i believe like 2" wide plastic piece of tubing. My power pipe is a Modular Power House4".
Old Dec 31, 2007 | 07:13 PM
tbirdscwd's Avatar
tbirdscwd
I think its something to do with the Blower using less force sucking the air into it, translating into more pressure on the other side.
Old Dec 31, 2007 | 09:41 PM
jEEd's Avatar
jEEd
I ♥ Acer
get the powerpipe and an IC!!!
Old Dec 31, 2007 | 11:21 PM
2000GT4.6's Avatar
2000GT4.6
be careful running more than 10 PSI.
The powerpipe should not need a retune if you have a good tune. MPH said I will not even need a retune after the i/c and powerpipe... just adding timing to each RPM stage via the xcal 2
