fuel pressure gauge install?
easy as pie. hook the sender on top of the shrader valve. will have to get a fitting though. then run the wires. find a switched 12v and use the blue/white wire coming from your headlight **** to use for the backlight power.
This is the shrader valve. It's on the end of the passenger side fuel rail. It won't look the same as yours, b/c I have it feeding my fuel solenoid for my N20, but you get the picture.
its at the end of the passenger side fuel rail. it looks like a tire stem. Just twist the cover off then release the pressure by sticking somthing in there as if you were letting air out of your tire. I just installed mine 4 days ago. Its really simple just a little time consuming to do all that wiring
