Something is wrong?
Old Jan 11, 2008 | 10:35 PM
Lombardo05's Avatar
Lombardo05
Default Something is wrong?
For some reason when im going about 25-40 mph and i floor it the battery icon on the dashboard lights up? ive never had this problem but about 2 weeks ago my battery kept dieng so iboughta different onethat will work with my system better and then no problems, know this happens... anyone know what this could be? dont know if this matter but i have a 2000 gt vert
Old Jan 11, 2008 | 10:48 PM
Noveds's Avatar
Noveds
Default RE: Something is wrong?
Start your car and lift a battery cable, if it dies it might be your alt. Have someone watch your dash while you flex the throttle. Does it light?
But since you say it only happens when you floor it, it may bea ground problem somewhere in your harness. You'll need a tech to find it. I had a Ranger that crapped out when I hit a bump from time to time. The local shade tree guy couldn't find it and I wound up paying a dealer a nice sum.
Old Jan 11, 2008 | 10:49 PM
my99gt's Avatar
my99gt
Your charging system has a problem. More than likelyyour altenator.
Old Jan 11, 2008 | 11:04 PM
racer02GTstang's Avatar
racer02GTstang
test it. put an multimeter on it and read the voltage its putting out.... if the car is off the battery should have over 12 volts. it needs over 11.8 volts to start so im told. when the car is running it should be pushing over 13 volts. it normally will have around 13-14.5... then rev the motor and see if that changes any in voltage for the better or worse... also see if the alternator is loosing charge as in with the car running the volts dropping slowly (this is best to see with a digital multimeter). then check and see if the battery is losing charge when the car is off and nothing is drawing power. check your belt to make sure it is tight because if there is no tension on the pulley im told the alternator will not charge the battery. it sounds like your alternator is starting to go though since it isnt charging well under a load. but test it before you replace it and thats not the problem.
Old Jan 12, 2008 | 12:32 AM
97targa's Avatar
97targa
sounds like your voltage regulator is crapping out. It's internal on your alternator so time to get a new alternator.
Old Jan 12, 2008 | 12:59 PM
Lombardo05's Avatar
Lombardo05
thanks alot for the information guys... im going to try that out in about 10 minutes. my dad told me he thought it was the alternator but i figured id get your guys thoughts too.
when i first got my system the subs kept cutting out b/c the alternator couldnt feed it fast enough ( even with a cap) so i tried to get it beefed up but no 1 will touch it? they say if they make it stronger it runs a risk of runing all the electronics in the car? anyone know where to get a deal on a stronger one? thanks again
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
