cams
Old Jan 29, 2008 | 10:59 AM
josh.davis's Avatar
josh.davis
Default cams
comp stage 2 or http://store.summitracing.com/partde...p;autoview=sku
stage 2 vt by jim-.560/.575 lift, 225/235 .050" duration, 108 LSA
http://www.cushmanmotorsports.com/in...oducts_id=1720
which one would make more power, and yes i am staying N/A.
Old Jan 29, 2008 | 12:06 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: cams
No brainer-custom grind
Old Jan 29, 2008 | 12:36 PM
josh.davis's Avatar
josh.davis
Default RE: cams
from who?
Old Jan 29, 2008 | 01:17 PM
10inch Terror's Avatar
10inch Terror
Default RE: cams
Mine have shown to make right around the same peak-to-peak power numbers as the Comp 270's, but mine tend to have a broader power range with more area under the curve. I had a customer swap out his 270's for my Stg 2 and went 2 tenths quicker with no other changes.
Old Jan 29, 2008 | 01:21 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default RE: cams
^ holy sig batman
Old Jan 29, 2008 | 01:37 PM
josh.davis's Avatar
josh.davis
Default RE: cams
how hard is it to tune in your cams? And what kind of springs will i need with your cams.
Old Jan 29, 2008 | 09:03 PM
defconfire's Avatar
defconfire
Default RE: cams
ORIGINAL: 10inch Terror
That is really amazing! I am really thinking about getting some stage 1's.
BTW: With your stage one do you usually just use the stock 2v redline or do you tend to bump it up a couple hundred rpm
Old Jan 29, 2008 | 09:11 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: cams
Jim, is that you? It's Mitch (formerly code3GT). I am out of the Mod. motor scene and running a pushrod now. Hope all is well.
Old Jan 29, 2008 | 09:39 PM
10inch Terror
Default RE: cams
ORIGINAL: 1SLO85
It's Me! What's new with you?
Old Jan 29, 2008 | 09:42 PM
10inch Terror
Default RE: cams
I'd likely suggest a dyno tune with them....unless you have a wideband and you know what you are doing.I'd suggest the Manley NEXTEK springs.
