Forcasting for 12's
Today, spent a few bucks.
Procharger stage 2 intercooled 10 psi kit
Accufab 75mm TB and Plenum
Diablo Mofia
2 Gauge Pod
Autometer Boost Guage and Air/Fuel Guage
Set of slicks
Mods are already as follows: 3:73's,Diablo Tune,FlowMaster Cat Back.
Is there any 12 sec 1/4 mile runs in my future?????
Diablo Mofia
2 Gauge Pod
Set of slicks
O and unless you have a true wideband A/F gauge i wouldnt put in jus a A/F ratio all its gonna do is tell you inaccurate readings. Either spend the money on a real wideband or put in a Fuel Press gauge
instead of the plenum and t/b get a midpipe, should show more gains on a procharged car.
it should easily run 12s on drag radials, let alone slicks. on slicks, your going to break a axle or carrier if they are stock.
ORIGINAL: 2000GT4.6
you will be in the 12's easy and making enough to break axles with slicks. do you have sub frame connectors if not you will need some.breaking axles is just a chance you take unless you upgraded.
