BOUGHT A HP TWIN TURBO KIT!!
Old 02-15-2008, 11:25 PM
racer02GTstang
racer02GTstang's Avatar
Default BOUGHT A HP TWIN TURBO KIT!!
i did it finally and purchased my twin turbo kit. i got the stage 2 kit with twin t3/t4 57mm garrett turbo kit with the upgraded billet blow off valves.
2 - 50mm T3/T4 Garrett turbochargers with Jet-Hot® Sterling® ceramic-coated turbine housings.
2 - 38mm Tial wastegates.
1 - Jet-Hot® Sterling® ceramic-coated driver-side header with turbo mounting flange.
1 - Jet-Hot® Sterling® ceramic-coated passenger-side header with turbo mounting flange.
2 - Jet-Hot® Sterling® ceramic-coated downpipes.
2 - Jet-Hot® Sterling® ceramic-coated turbo intake tubes
2 - Jet-Hot® Sterling® ceramic coated turbocharger to intercooler tubes.
1 - Jet-Hot® Sterling® ceramic-coated mass air to intercooler tube.
1 - Jet-Hot® Sterling® ceramic-coated throttle body to mass air meter tube.
1 - Jet-Hot® Sterling® ceramic-coated intermediate pipe with bracket.
1 - Mass air meter calibrated for injectors (size may vary depending on year model).
8 - 42# fuel injectors.
1 - Fuel pump upgrade
96-98 systems - 255 lph in-tank pump
99-04 systems - Focus SVT pump upgrade
03-04 Cobra system - Boosta-pump upgrade optional
1 - Tubular K-member.
1 - Tubular control arms.
1 - Coil-over conversion system.
1 - Set caster/camber plates.
1 - Computer Upgrade Chip.
1 - 25" x 14" x 3½", 3-row Aluminum custom intercooler assembly.
1 - Intercooler bracket.
2 - Billet aluminum turbocharger oil outlet fittings.
2 - Turbocharger oil inlet fittings.
2 - Turbocharger intakeair filters and clamps.
2 - Turbocharger oil outlet hoses.
4 - Turbocharger oil outlet hose fittings.
2 - Turbocharger oil inlet hose assemblies.
2 - Turbocharger compressor housing clamps.
2 - Turbocharger oil inlet fittings - turbocharger side.
2 - Pressure port tees.
2 - Oil tee extensions.
2 - Blow off valves.
2 - 1” Blowoff valve hoses.
4 - 1” Blow off valve hose clamps.
1 - Lot 3-ply Silicone Hose Couplings.
1 - Lot Stainless Steel V-Band Clamps
1 - Lot Stainless Steel T-Bolt Clamps
1 - Lot Misc. Nuts, bolts, washers
1 - Lot Exhaust Clamps
1 - Detailed turbocharger system installation manual.
racer02GTstang is offline
Old 02-15-2008, 11:40 PM
01GT4.6
01GT4.6's Avatar
Default RE: BOUGHT A HP TWIN TURBO KIT!!
nice, do you plan on swapping the cams?
01GT4.6 is offline
Old 02-15-2008, 11:52 PM
racer02GTstang
not as of yet.... ive been told they should work and such so i will see how it does with these cams and maybe eventually get the turbo cams and retune.
Old 02-16-2008, 12:24 AM
stangman2354
stangman2354's Avatar
if you don't mind me asking. how much was all of that?
stangman2354 is offline
Old 02-16-2008, 12:35 AM
GhostRider02GT
GhostRider02GT's Avatar
congrats, are you the first of the 2V's to be TT?? (on mF)
I also wanna know how much
GhostRider02GT is offline
Old 02-16-2008, 12:49 AM
96stanGTR
96stanGTR's Avatar
mmmmmmmm thats hottt.
96stanGTR is offline
Old 02-16-2008, 12:50 AM
livefast1
livefast1's Avatar
nice ive been contemplating doing my own custom turbo kit for my car, i hear turboforums.com has quite a few knowledgable turbo guys over there so i may direct some questions there way if i decide to pull the trigger on this platform when i graduate college.
livefast1 is offline
Old 02-16-2008, 01:03 AM
Zoie_daGT
Zoie_daGT's Avatar
Very awesome!!!! What kind of numbers are you shooting for???
For those of you that asked, it cost many, MANY clams....hahahhaa
[align=left] [/align]
Zoie_daGT is offline
Old 02-16-2008, 01:05 AM
dougs97mustang
dougs97mustang's Avatar
what kind of power will that give you? and have you had any internal engineparts replaced?
dougs97mustang is offline
Old 02-16-2008, 01:06 AM
racer02GTstang
i spent 6300 total for the twin turbo setup. this is including a better maf and such as well.
i still do need to get a boost controller for this setup though which im still not too sure on which one i am wanting to get.
Quick Reply: BOUGHT A HP TWIN TURBO KIT!!
