adding sub and amp to mach 460
Old Feb 16, 2008 | 09:59 PM
Cornbread01's Avatar
Cornbread01
Default RE: adding sub and amp to mach 460
ill take a pic of the harness i have in my car tommarow if you want me to... so you have an idea what it looks like i beleave there are two
Old Feb 16, 2008 | 10:04 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
so this is the head unit that you are using?
Old Feb 16, 2008 | 10:21 PM
kingofqueenz's Avatar
kingofqueenz
yea but it doesnt have cassett, the headunit doesn't matter for the questions im asking, although u had cassette and i have cd, our data cables in the trunk are the same, which is where i think my problem might be.
Old Feb 16, 2008 | 10:35 PM
Cornbread01
if your using a stock head unit witch is not ideal..... you need to buy an adapter that is speaker wire on one end and rca on the other... that is were you will get your rca input to the amp from the remote will goto a wire that gets hot when the ignition is on. the rest is just power and ground then the speaker wires. the rca adapter needs to tap into the rear speakers, speaker wire.
Old Feb 16, 2008 | 10:55 PM
mustanglee's Avatar
mustanglee
check out this site on mustang world http://www.mustangworld.com/ourpics/fcar/despeeds1.htm
Old Feb 16, 2008 | 10:59 PM
mustanglee's Avatar
mustanglee
http://www.mustangworld.com/ourpics/fcar/despeeds1.htm soprry the first one did not come out but go to Mustang world.com and click on how to's they tell you how to install a sub to your stock system
Old Feb 16, 2008 | 11:25 PM
kingofqueenz
i followed this from mustangworld but i didn't use all 4 wires from the data cable since i was using just 1 sub and 1 amp, was i supposed to splice all 4?
Old Feb 17, 2008 | 09:18 PM
kingofqueenz
bumpp
Old Feb 17, 2008 | 09:47 PM
mvr's Avatar
mvr
i followed the mustangworld while wireing one sub and one amp onto my stock 6disk 460. no problems, had it in for over a year and a half.
Old Feb 17, 2008 | 10:33 PM
kingofqueenz
hey, can you tell me how you spliced the data cable in the trunk and how u put it into the line-out converter?
