NEED HELP WITH NEW THROTTLE BODY!
Old Feb 17, 2008 | 02:28 PM
STEELERS99MUSTANG's Avatar
STEELERS99MUSTANG
Default NEED HELP WITH NEW THROTTLE BODY!
I just installed a new 75mm throttle body on my 1999 4.6 Gt and the check engine light is staying on. Do I have to install a new upper 75mm plenum to have light shut off? any help would be great! Thanks
Old Feb 17, 2008 | 02:36 PM
texas_stang02's Avatar
texas_stang02
Default RE: NEED HELP WITH NEW THROTTLE BODY!
you don't have to put a new plenum on. did you make sure all the wires and hoses are hooked back up how they were? if you've got a handheld tuner that can read codes, then try that, or you can take it to an auto parts store, i think most of them can read it as well. if not, then try swapping the original back on there and see if the light goes off, but a new tb shouldn't trigger a check engine light.
Old Feb 17, 2008 | 02:43 PM
AZsFinest's Avatar
AZsFinest
I ♥ Acer
unplug ur battery than put it back on. If the light returns in a couple of hours or a day then get ur handheld and delete it.
Old Feb 17, 2008 | 03:41 PM
STEELERS99MUSTANG
Thanks, I tried the battery thing but stayed on so I need to get a handheld.
Old Feb 18, 2008 | 12:07 AM
AZsFinest's Avatar
AZsFinest
I ♥ Acer
honestly it might just go away over time. When first installed my CAI my light stayed on for about a day then just turned off. The sensor had to adjust itself to the new amount of air coming through. Hopefully its nothin serios. I dont think it is though.
Old Feb 18, 2008 | 06:28 AM
jrherald420's Avatar
jrherald420
give it a day or so then take it to autozone and get it checked
Old Feb 18, 2008 | 11:32 AM
STEELERS99MUSTANG
Thanks for info
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
