Getting built in April
RE: Getting built in April
ORIGINAL: boostedgt02
Here is a list of everything that will be getting installed in April.
Eagle 302 stroker kit
ESP 4340 Steel Crankshaft
Eagle H-Beam Rods
Arias Custom Blower Pistons/Coated
Arp Head Studs and Arp Main Studs
Novi 2000
Power Pipe
GT pumps
8 rib pulley set
Wolfecraft Upper/Lower Control Arms
Strange Shocks/Struts
Roll Cage 6 point
Corbeau Seats A4 Black w/4 point harness
Comp Cams Staged 2 heads
Comp Cam Gears
60lb injectors
CPR fuel rail
TFS
Acufab TB
MSD Coil Pack
TK-600
Micronite TK-600 Gears
Billet Flywheel
Lakewood Bell Housing
SPEC 3 Clutch
Safety Loop
Eibach Launch kit w/bag
31 spline/ eaton posi
Rear end cover
Paxton Intercooler
Kooks custom headers w/ catted X
Magna Flow Catback
Slotted Rotors
Heat Extract Hood
Let me know what you think???
Eagle H-Beam Rods
Novi 2000
Power Pipe
GT pumps
8 rib pulley set
Roll Cage 6 point
Comp Cam Gears
60lb injectors
CPR fuel rail
TFS
Acufab TB
MSD Coil Pack
TK-600
Billet Flywheel
SPEC 3 Clutch
Safety Loop
Rear end cover
Paxton Intercooler
Magna Flow Catback
Slotted Rotors
Heat Extract Hood
not only that I've heard its alot more stress on the engine when you increase the stroke that much.
On an agressive tune at 13lbs of boost I saw about 520rwhp at 6800rpm. Since your going with the manual, you'll be further ahead than I am
I have a little more in parts and I think the cost on mine came to around 27-$28,000, good luck with it. I'm guessing your going for an all out straight line car? I think except for the suspension and the blower, our set-up's will be quite similar. Like I said, good luck with it all, just make sure you really trust the shop your using.
Little horror story about the shop I use - I had them fabricate another couple oil lines for me, and they put the belt on wrong- shredded it all to he** within 100-150 miles. all my advice is just check stuff over and make sure it's done right, and never trust jack furrier's tires -they didn't even retorque the lug nuts down.
ORIGINAL: 2000GT4.6
Ever had anything even remotely close to this, or are you going from a boltons GT to a 600+ WHP car? If you haven't... I hope we don't see a "caris wrecked" about 2 days after the install.
Gonna guess there is about 600-650 WHP there. Real hard to make more than that on a blower car 2v.
and I have been in some insanely fast cars, and all of them have been under 600rwhp. Thats going to be an insane car
ORIGINAL: 2000GT4.6
Guys im overseas just taking the car out every once and a while on the streets and will drag in august but will soon turn into an all out drag car once i buy my house. Then I will change it to an auto with twin turbos.
You can get a billet shortblock in regular 281CI form as well though, and cheaper too.,
The bore/stroke ratio of the 4.6L is great stock. Stroking it makes the ratio worse, and costs you RPM potential, definatly not something you are going to want for your forged block/centri charged motor with all the head porting etc.
Its just not enough CI to make up for the loss of good ratio etc etc IMO. I have yet to see a single stroker make any more power with the same setup as a 281 or 281 + .030 overbore setup.
Car is going to be mean either way, but you could spend the extra dough from the stroker on something else.
From what I have seen its just hard to make more than about 600-650 on a blower car 2v for some reason. Several have made more with turbo kits or blower + nitrous though.
650ish WHP is good for mid 10s on the right suspension/launch though... dammed fast for a street car.
This isn't your DD is it? The mods your talking about are going to really transform the car... enough that your not going to want to DD it.
