Getting built in April
Here is a list of everything that will be getting installed in April.
Eagle 302 stroker kit
ESP 4340 Steel Crankshaft
Eagle H-Beam Rods
Arias Custom Blower Pistons/Coated
Arp Head Studs and Arp Main Studs
Novi 2000
Power Pipe
GT pumps
8 rib pulley set
Wolfecraft Upper/Lower Control Arms
Strange Shocks/Struts
Roll Cage 6 point
Corbeau Seats A4 Black w/4 point harness
Comp Cams Staged 2 heads
Comp Cam Gears
60lb injectors
CPR fuel rail
TFS
Acufab TB
MSD Coil Pack
TK-600
Micronite TK-600 Gears
Billet Flywheel
Lakewood Bell Housing
SPEC 3 Clutch
Safety Loop
Eibach Launch kit w/bag
31 spline/ eaton posi
Rear end cover
Paxton Intercooler
Kooks custom headers w/ catted X
Magna Flow Catback
Slotted Rotors
Heat Extract Hood
Let me know what you think???
Eagle H-Beam Rods
Novi 2000
Power Pipe
GT pumps
8 rib pulley set
Roll Cage 6 point
Comp Cam Gears
60lb injectors
CPR fuel rail
TFS
Acufab TB
MSD Coil Pack
TK-600
Billet Flywheel
SPEC 3 Clutch
Safety Loop
Rear end cover
Paxton Intercooler
Magna Flow Catback
Slotted Rotors
Heat Extract Hood
RE: Getting built in April
Ever had anything even remotely close to this, or are you going from a boltons GT to a 600+ WHP car? If you haven't... I hope we don't see a "caris wrecked" about 2 days after the install.
Gonna guess there is about 600-650 WHP there. Real hard to make more than that on a blower car 2v.
