updates of my rebuild (pix)
the start
stripped down
the stockers
bare block
pistons
rods
a little painting (poor quality, but who cares lol)
bearings
the big difference
motivational drinker haha
cousin paul filing rings
where i'm at so far
right now the crank & 1 piston/rod is at the shop getting balanced. my Patriot Performance Stage II heads are in the mail (supposed to be anyways), and i'm ordering the cams from MPH on wednesday. i'll update this as the process moves along and i get more pictures to post.
stripped down
the stockers
bare block
pistons
rods
bearings
the big difference
where i'm at so far
RE: updates of my rebuild (pix)
ORIGINAL: fausty
i wish i was you right now.not to be nosy but how much is the build going to come out to?
balancing- $280
block work- $200
heads- $1300
cams- $600
cam gears- $300
255Lph fuel pump- $120
30# injectors- FREE (got 'em from my cousin)
gaskets- +-$400
over $5,000, plus i'm doing some other this such as:
new throwout bearing- $65
a/c eliminator bracket- $30
sniper tuner- $340
high volume oil pump- $52
7qt. oil pan from moroso- $260
full length subframe connectors and upper/lower control arms- $220
18' fr500's- $1100
hood pins (need 'em, not just for looks)- $35
bumpsteer kit- $150
swarr bar- $160
Autometer gauge cluster- $350ish
smoked headlights w/clear corners- $200
rear seat delete- $130
3-pillar gauge pod and gauges- $135
shift light- $30
billet fuel door- $100
FRPP billet pedals- $50
built 31 spline rear end- $1000+-
tko500- $2000ish
looking at putting almost $12000 into the stang this year. last summer i put $5000 into in in just bolt-ons. $17,000 into a car i paid $11,000 for, and it'll still only be worth about $9,000 hahaha. this things we do
