? ABOUT THE 2V
what goes bad what these 2v. i know they are not perfect motors and they do have issues so what are the problem. the only reason i wanna know is b/c i wanna see if its work building it up or to buy a 4v. right now i have 64000 miles almost 65. am i better off saving my money for a new motor?
Typical issues are spark plug blow outs and a few people have had issues with timing chains here.
Best plan would be to run a leakdown/compression test every so often and as long as you have no detonation, knocks or smoke you can feel fairly confident nothing is going to go bad.
so i should feel confident if i put new heads, cams on. should i even worry about the bottom end at all. i have had a pinging issue witch i believe it was from ditination but is fixed now with a custom tune. if the ditination didnt cause any issues before could it cause any in the future? i wanna get my car to push 300 to the rear. or should i not even waste my time with the 2v?
If your motor wasn't trashed on that thing will hold on for a lot longer than you think. 65k on a taken care of 4.6 is almost as good as rolling out the factory. Forget heads/cams that doesn't add much power for your money, you could get a 75-100 shot for 1/3rd the cost and be well over your goal.
There's people on here with nitrous/SC with 150k+ miles. Keep that in mind.
if you look at the hp and tq that im already pushing with the mods i have seems that my stang is taking well to mods and if i put on a set of heas and cams i wounder if i would be pushing 300 rwhp.
ORIGINAL: MUSTANGO2GT
If your on a budget a nice shot of nitrous will be way cheaper and get you much more than 300 rwhp.
thing is i will never put a bottle on my car. im to worried about dmging the motor. i rather be n/a or s/c. do the motors hold up well if its s/c and over 100,000 miles? ty the way i really like your car Quick Shot xMLx.
Thanks for the car compliment[8D]
i guess im going to have to start saving now for a s/c. i got 2 hundred buck in my saving now so i gues its going to be a while until i can afford a 5,000 s/c. let say either a year to 2 i should have one lol
