LCA
Old Mar 8, 2008 | 11:28 PM
avlon06's Avatar
avlon06
Default LCA
they worth the investment, looking for somethign to help me with auto x
Old Mar 8, 2008 | 11:40 PM
avlon06's Avatar
avlon06
Default RE: LCA
bump
Old Mar 9, 2008 | 12:01 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default RE: LCA
Adjustable type is the only way to goespecially since I assume you'll be lowering your car for handling purposes. It'll help control axlebind and willhelp withunwanted axlearticulation.Solid LCA's will provide a more solid feel although some find it "harsh". However forauto-x you may find that polylower control arms are too mild and in mostcases are just agoodstockreplacement.
Solid/poly upper control arms are great for controlling that "tail-wag" feel that you might have if you've ever taken a bumpycorner under power. Since you can get the pair for 199.99 from UPR I would highly recommend looking into the pair since you'll be under there replacing them anyways.
Old Mar 9, 2008 | 12:25 PM
jrherald420's Avatar
jrherald420
Default RE: LCA
i bought the uprupper and lower control arms and it made a big diffrence to me. the rear end had very little if any wheel hop on a hard take off and carving corners was alot better!! it felt tighter to the road. the one thing i didnt like was with the new arms in the backyou could feel the diffrence in the front it feels looser now but a k member is on the books for that problem. to make a long story short its the best 209.99 i have ever spent.
Old Mar 9, 2008 | 01:15 PM
hpwrestler220's Avatar
hpwrestler220
Default RE: LCA
ORIGINAL: jrherald420
is it 210 for both UCA's and LCA's?? or just the LCA's?? did you install urself?
Old Mar 9, 2008 | 04:57 PM
jrherald420
Default RE: LCA
yes andupper and lower control arms. it took 2 hours start to finish.
Old Mar 9, 2008 | 05:31 PM
hpwrestler220
Default RE: LCA
hm.. i may do this if it greatly improves traction and cornering
Old Mar 9, 2008 | 06:04 PM
jrherald420
Default RE: LCA
that it does, but if you dont have good tires there useless.
Old Mar 9, 2008 | 07:16 PM
hpwrestler220
Default RE: LCA
idk. we'll see if my tires are good once the warm weather comes.. when it was 60 degrees i took my car from5mph in 1st and mashed the gas and didnt spin at all. so i guess warm weather plus tokico shocks/struts = good?? idk
to the OP: sorry for stealing this thread
Old Mar 9, 2008 | 07:25 PM
JayC's Avatar
JayC
Default RE: LCA
Exactly, spend you money on tires and brakes for Auto-X[8D]
