rubber intake tube
Old Mar 19, 2008 | 04:46 PM
5speed01GT's Avatar
5speed01GT
Default rubber intake tube
i hate it and dont want to spend the extra money on cold air intake so is there any way i can just have a pipe there that leads to my k&N filter
Old Mar 19, 2008 | 05:16 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: rubber intake tube
ORIGINAL: 5speed01GT
JLT uses plumbing PVC and paints it, why can't you??
Old Mar 19, 2008 | 05:21 PM
5speed01GT's Avatar
5speed01GT
really....thats all it is
pvc pipes?
Old Mar 19, 2008 | 05:22 PM
lizzyfan's Avatar
lizzyfan
Underboss
pvc pipes?
Yea man!
Old Mar 19, 2008 | 05:51 PM
5speed01GT's Avatar
5speed01GT
will it give me any more hp or anything
and if its so simple as pvc pipes why does it come with the rubber tube
Old Mar 19, 2008 | 06:13 PM
MoKo_04GT's Avatar
MoKo_04GT
the stock rubber intake tube has ribs on it, which is said to cause turbulance...which is said to have a negative effect on performance. of course a strait/smooth intake/pipe would get rid of the turbulance, for better/smoother air flow. its not going to feel like you slapped a supercharger on there, if you chage it....but every little bit helps. plus it looks a ton better. the JLT intake pipe is 4 inches in diameter, to give you an idea of what to purchase. it does come with these little reducer pieces to make it fit to the throttle body tho. that part might be kinda hard.
Old Mar 19, 2008 | 06:34 PM
5speed01GT's Avatar
5speed01GT
so i can just buy an intake pipe rite...like i dont want to go get a whole new air filter setup
Old Mar 19, 2008 | 06:38 PM
MoKo_04GT's Avatar
MoKo_04GT
as long as you can get everything to fit together ok, and without leaks, you should be good to go.
Old Mar 19, 2008 | 06:44 PM
y2kStangGT's Avatar
y2kStangGT
there was a guy on here who made his own.
he has all the angle degree and stuff.
try the search function
Old Mar 19, 2008 | 06:47 PM
01GT4.6's Avatar
01GT4.6
ORIGINAL: MoKo_04GT
the ribs are on the OUTSIDE and do not effect performance at all.
