Cams
Old Mar 24, 2008 | 03:22 PM
Kmelfi11's Avatar
Kmelfi11
Default Cams
I know i want stage 1 cams, but what kind should i get? any one else running stage 1 cams?
Old Mar 24, 2008 | 04:23 PM
MaKaVeLi's Avatar
MaKaVeLi
Default RE: Cams
http://www.cushmanmotorsports.com/in...78d42c678ba88f
i got mine from this website, they are the same grind as the famous VT cams
and yeah they are great!
Old Mar 24, 2008 | 04:49 PM
hpwrestler220's Avatar
hpwrestler220
Default RE: Cams
wow.. stage 2's only give like 5 more hp but you have to buy new valve springs... whats the point?? stage 1's FTW it looks like.. but 30rwhp??? not with just2 cams.. maybe with ported heads???
Old Mar 24, 2008 | 05:06 PM
tws1098's Avatar
tws1098
Default RE: Cams
I have never heard bad things about comp cams stage 1s
...but....
You will probably spend a good 5-600 on cams, have you considered just saving for a s/c or you could buy a nitrous kit for that kind of money if you are into that sort of thing. Just a suggestion. Good luck either way.
Old Mar 24, 2008 | 05:37 PM
Kmelfi11's Avatar
Kmelfi11
Default RE: Cams
i dont want nitrous and i dont want to blow this motor, my friend in a bolt on GT blew a rod through his block, id rather just wait and do it the right way. so i wana cam it to just have some more power then i have now because im getting bored, but i dont wana get heads right now and spend that much money. But if i get them im gana get a custom tune, how much hp do you think ill get?
Old Mar 24, 2008 | 05:56 PM
01snake's Avatar
01snake
Default RE: Cams
ORIGINAL: Kmelfi11
how many miles were on the car
as far as cams if your gonna do it, do it right and get ported heads to go along with the cams.
and persoanlly i wouldent waste my time with stage 1's at least stage 2's
Old Mar 24, 2008 | 06:10 PM
Kmelfi11's Avatar
Kmelfi11
Default RE: Cams
who has stage 1's and do you like them?
Old Mar 25, 2008 | 08:03 AM
Kmelfi11's Avatar
Kmelfi11
Default RE: Cams
bump
Old Mar 25, 2008 | 08:14 AM
Kmelfi11's Avatar
Kmelfi11
Default RE: Cams
Stage 2 Cams
if i went stage 2 i know i have to get new springs but if i was to wait on the heads and do that another time because of money, i know i wouldnt see as much hp gains but would it still run good?
Old Mar 25, 2008 | 03:31 PM
defconfire's Avatar
defconfire
Default RE: Cams
I think that i am just going to go with stage 1's because with stage 2 you need the springs and a tune is "required" I also just dont think i need to be shifting at 6800 rpm. Not worth it for an extra 5-10 hp IMO
