TPS code?
Old Apr 9, 2008 | 12:03 AM
Gar4pt6's Avatar
Gar4pt6
Default TPS code?
so i ran a diagnostics check on my check engine and it says (on my diablo tuner) "Throttle/Pedal Position Sensor A, Low circuit input"
i know its something to do with the TPS but whats sensor "A" and whats "low circuit input" maen and lasttly how do i fix it?
Thanks
Garrett
Old Apr 9, 2008 | 11:22 PM
Gar4pt6's Avatar
Gar4pt6
Default RE: TPS code?
bump
Old Apr 9, 2008 | 11:47 PM
Gianni's Avatar
Gianni
i learned some stuff bout the TPS basically wen u put the gas pedal down the computer is not reading it nd is not tellin ur throttle 2 open im guessin circuit A nd low circuit input basically means the TPS is not getting the message...i would check the wires leading 2 ur TPS or c if u have a loose connection...thats pretty much all i kno if that helps
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
