---------NEED HELP!!!!---------
Old Apr 14, 2008 | 02:29 AM
AMERICANMUSCLE96's Avatar
AMERICANMUSCLE96
Default ---------NEED HELP!!!!---------
My service engine light came on last week. I did not notice a difference in the cars performance right away, but every once in awhile while the car is at low idle, it feels like it is not getting enough gas. I scanned the car, and 2 codes came up, p1151 and p1151. I did some searching on here and most people on here said it is a vacuum leak of some sort or a o2 sensor is bad. I know there is 4 o2's in the car, but not sure which ones I should change. I dont want to change all of them if I dont need to. Any help would be appreciated.
Thanks
Old Apr 14, 2008 | 09:11 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: ---------NEED HELP!!!!---------
Change your thread subject so it's likely to be read instead of entirely ignored. [8D]
Old Apr 14, 2008 | 09:30 AM
1sloblckgt's Avatar
1sloblckgt
ORIGINAL: AMERICANMUSCLE96
Thanks
??? You listed p1151 twice.
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
Old Apr 14, 2008 | 10:03 AM
Fizzics Boy's Avatar
Fizzics Boy
Check for any vacuum leaks. If none are found go out and buy a new oxygen sensor. The one in question is the drivers side up by the manifold.
Old Apr 14, 2008 | 11:10 AM
Sxynerd's Avatar
Sxynerd
ORIGINAL: 1sloblckgt
Thanks
You're still around... I thought you dropped off the planet.
The O2's need to be changed...
Old Apr 14, 2008 | 11:26 AM
1sloblckgt's Avatar
1sloblckgt
ORIGINAL: sxynerd
Thanks
You know me. Just trying to help when I can...
Old Apr 14, 2008 | 12:36 PM
timeformiller44's Avatar
timeformiller44
what year .... motor???? i can help u out but i need alil more info
Old Apr 14, 2008 | 12:52 PM
slammedandcammed's Avatar
slammedandcammed
This is my other log in from my work account, the car is a 01 GT 4.6, the codes were 1151/1152. I believe I read on here somewhere that it was the passenger upper o2 sensor, but just trying to be correct before I change it. Thanks for the help
Old Apr 14, 2008 | 08:32 PM
AMERICANMUSCLE96
Anyone else?
Old Apr 17, 2008 | 11:06 PM
AMERICANMUSCLE96
I guess everyone quit looking, thanks for the help.
