***My Spring Build***
RE: ***My Spring Build***
i am cruious tooo.. ^^^^
also bought the nittos bc running low on cash and needed a tire to last me alil longer ... next set will be BFG's
also the heads will have bigger valves and better springs and that
Just some advise. Pull the motor. It will make what your doing alot eaiser. Heads, timing the cams, clutch and tranny reinstall will all be alot easier with the engine out. You are only about 15min of work away from pulling the engine out if you got a cherry picker.
Nittos suck *** on stock suspension/ bad driver cars. I use then and am pulling the front wheels off the ground. I have never tried anyother tire cause I havn't found a need to.
