gauge install question
Old Apr 15, 2008 | 10:14 PM
stangman2354's Avatar
stangman2354
Default gauge install question
I remember someone posted up a good article or how-to about installing gauges. Just the normal wire part that every gauge has like the power and ground. It was an article about getting an add a fuse, but I recently took mine out and forget how to do it. so if anyone knows how or has an article post it.
Old Apr 15, 2008 | 10:27 PM
Stang SS's Avatar
Stang SS
Default RE: gauge install question
http://www.americanmuscle.com/mustan...es-how-to.html
Old Apr 15, 2008 | 10:46 PM
stangman2354
I appreciate your help, but I mean gauges like boost gauges and wideband things like that.
Old Apr 15, 2008 | 10:49 PM
Stang SS's Avatar
Stang SS
o one sec i think i have one saved on my comp...
Old Apr 15, 2008 | 10:51 PM
Stang SS's Avatar
Stang SS
hopes this is what you are looking for....
http://www.speedofsoundllc.com/i/Ins...structions.pdf
Old Apr 15, 2008 | 11:15 PM
stangman2354
you're getting closer lol. but no.
I don't need to know how to install the a pillar or the boost/vacuum gauge. I just need to know how to wire up the gauge to make it turn on and off. I remember I bought a add a fuse and I plug it into my fuse box under the dash, but I forget what fuse I put it in. also what to wire it up to. to make the gauges turn on. Hope this helps.
Old Apr 16, 2008 | 02:13 PM
stangman2354
bump
Old Apr 16, 2008 | 07:32 PM
WOH HRSY's Avatar
WOH HRSY
I wired mine into the light switch itself, I THINK it was a blue/white stripe wire. I can't find the write up I used for that so your wire color may be different but you can check for that one.
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
unit91
Aug 21, 2015 11:44 PM
jjwinel78
Aug 17, 2015 03:34 PM
HIS S-197
Aug 10, 2015 05:47 PM
