k member
Old Apr 17, 2008 | 09:56 AM
99 GT vert's Avatar
99 GT vert
Default k member
on american muscles website they have a Maximum Motorsports K Member and it says it comes with the front coil over conversion kit does that mean that it comes with the coil over kit would i still need to get lowering springs when i lower it
Old Apr 17, 2008 | 10:17 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default RE: k member
No, you choose your spring length and rate when you buy the kit. Call and talk to a rep if you're not sure what you're looking for because usually they offer 8-10 different options.
Old Apr 17, 2008 | 10:22 AM
99 GT vert's Avatar
99 GT vert
so i could chose any springs i wanted to go with
Old Apr 17, 2008 | 10:24 AM
35thAnni99GT
basically. A coil-over is a combination of the strut and coil spring combined. In a stock setup the strut is mounted separately from the coil.
Old Apr 17, 2008 | 10:25 AM
99 GT vert's Avatar
99 GT vert
ok so would it be better to get the rears at the same time
Old Apr 17, 2008 | 10:37 AM
jmac72187's Avatar
jmac72187
corner carver
Make sure that you have the correct struts to use with the MM coilovers. Their coilovers are brand specific.
MM told me that rear coilovers are not very street friendly.
While front coilovers are a great way to go regardless of application, the rears are not quite as street friendly. I typically recommend staying with conventional location springs in the rear.
Old Apr 17, 2008 | 10:41 AM
35thAnni99GT
^^[sm=signs007.gif]
typically they provide you with a strut, but just call to make sure.
Old Apr 17, 2008 | 10:44 AM
99 GT vert's Avatar
99 GT vert
should i call MM or american muscle
Old Apr 17, 2008 | 10:52 AM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: 35thAnni99GT
^^[sm=signs007.gif]
The MM K-member kit isn't going to include struts. Their coil-over kits do not include the struts. They only include the parts needed to switch to coil-overs. You have to decide on which struts you want and then buy the appropriate coil-over kit.
Old Apr 17, 2008 | 10:56 AM
99 GT vert's Avatar
99 GT vert
so when i decide to do this i will need to get different struts or will my stock ones work
