k member
Old Apr 17, 2008 | 10:57 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Default RE: k member
I stand corrected[]
Old Apr 17, 2008 | 12:37 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: 99 GT vert
so when i decide to do this i will need to get different struts or will my stock ones work
You are going to have to upgrade your struts. MM makes coil-over kits for Bilstein and Koni/Tokico. I plan on going with the Bilstein HD shocks/struts all around and then converting to the coil-over kit in the front shortly after.
Old Apr 17, 2008 | 12:47 PM
Ryan86272's Avatar
Ryan86272
From AM Website Just under the Price(keep Reading)
"Proper installation of the K-Member will also require the use of the following parts:
[ul][*]Tubular front control arms (stock control arms are not compatible because of the large outside diameter of the pivot bushings)[*]Caster/Camber plates[*]Front Coil-Over conversion kit[*]Aluminum steering rack bushings[*]MM Adjustable Tie-Rod Ends "
[/ul]
Old Apr 17, 2008 | 01:03 PM
99 GT vert's Avatar
99 GT vert
ORIGINAL: Ryan86272
[ul][*]Tubular front control arms (stock control arms are not compatible because of the large outside diameter of the pivot bushings)[*]Caster/Camber plates[*]Front Coil-Over conversion kit[*]Aluminum steering rack bushings[*]MM Adjustable Tie-Rod Ends " [/ul]
you know i read all of that but for some reason i thought that it was included wow i feel dumb now
Old Apr 17, 2008 | 01:22 PM
Ryan86272's Avatar
Ryan86272
ORIGINAL: Ryan86272
It makes sense now.... i was goanna say the K member comes with(Everything u listed in the First Post) For that price!!! Wow.... UPR's With EVERYHTING is like 1200 lol.... I would love to get a K-member/Coilover kit!!!!
Old Apr 17, 2008 | 02:55 PM
99 GT vert's Avatar
99 GT vert
UPR
does this kit have evry thing i need or is there more that i would need to get
i know that i would need struts with this also but other than that
Edit: last kit on the page
Old Apr 17, 2008 | 03:03 PM
jmac72187's Avatar
jmac72187
corner carver
UPR
You would also need CC plates. Other than that it includes everything.
Old Apr 17, 2008 | 03:05 PM
99 GT vert's Avatar
99 GT vert
ok thanks
Old Apr 17, 2008 | 03:09 PM
Ryan86272's Avatar
Ryan86272
Call, them and talk to them.... You will get a Discount if you say" i was talking to you guys at FFW in bradenton" (say u were on vacation down there) u will get it for whatever it was onsale for.. but very nice guys, the kit they had he said i would need some more stuff... soo call and ask, and be sure to say u saw their Trailer at FFW Bradenton.
Old Apr 17, 2008 | 03:11 PM
99 GT vert's Avatar
99 GT vert
ok thanks i will
Coyote_hpr
Nov 12, 2019 12:44 PM
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
