QUESTION???
Old May 3, 2008 | 12:21 PM
timeformiller44's Avatar
timeformiller44
Default RE: QUESTION???
ORIGINAL: DIY
^^^That is a good question. A loose chain will more than likely jump the cam gear and throw the timing out of place.As far I know, the only sign of a problem you 'll receive is when the engine blows as a result of this. However,this isn 't a likely scenario with the 4.6. The weak link in the timing chain set up isn 't the chain but the chain tensioners. Signs to look/listen for would bea ticking sound. Check the stickies for more information on this.
and very bad things will come of this lol if that happens
+1
Old May 3, 2008 | 12:33 PM
Dan04COBRA's Avatar
Dan04COBRA
Interference motors....When a tensioner breaks, you will have severe interference resulting in flags on the play and a lot of time sitting on the sideline to reflect.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
