QUESTION???
Old May 3, 2008 | 08:24 AM
brianispimp03's Avatar
brianispimp03
Default QUESTION???
WHEN IS THE PROPER MILEAGE TO CHANGE THE TIMING CAINS ON AN 03 MUSTANG GT???
Old May 3, 2008 | 09:04 AM
steve0914's Avatar
steve0914
Default RE: QUESTION???
why are you yelling?
Old May 3, 2008 | 09:12 AM
Sxynerd's Avatar
Sxynerd
ORIGINAL: brianispimp03
Never.....
oh and one more thing...
Old May 3, 2008 | 09:58 AM
brianispimp03
sorry bout the caps lock i was just wonderin bout the timing chain???
Old May 3, 2008 | 10:04 AM
steve0914's Avatar
steve0914
you dont have to unless its bad.
Old May 3, 2008 | 10:18 AM
brianispimp03
ok appreciate it. will it make any sort of racket or anything when its starting to get loose??
Old May 3, 2008 | 10:27 AM
black35th's Avatar
black35th
https://mustangforums.com/m_4162707/tm.htm This is a sticky in the tech section, it will make a ticking noise. Read on...
Old May 3, 2008 | 10:37 AM
DIY's Avatar
DIY
^^^That is a good question. A loose chain will more than likely jump the cam gear and throw the timing out of place.As far I know, the only sign of a problem you 'll receive is when the engine blows as a result of this. However,this isn 't a likely scenario with the 4.6. The weak link in the timing chain set up isn 't the chain but the chain tensioners. Signs to look/listen for would bea ticking sound. Check the stickies for more information on this.
Old May 3, 2008 | 10:38 AM
Cornbread01's Avatar
Cornbread01
when you snap one like i did lol
Old May 3, 2008 | 10:39 AM
DIY's Avatar
DIY
The sticky I referred to is in the tech section.
