High Idle????
Old May 13, 2008 | 09:28 AM
bravesfan's Avatar
bravesfan
Default High Idle????
Have a 97 mustang gt w/bbk cai & 70 mm throttle body. No other major mods. The idle one day is normal and the next at about 1700 rpm's. The past week is has been on the high side. Cleaned the maf, iac and still no improvement. Put a restricter on the iac, read somewhere that this might help and needless to say it did not. Any advice would help. Thanks in advance.
Old May 13, 2008 | 09:56 AM
ColinGT's Avatar
ColinGT
Default RE: High Idle????
Im no mustang pro nor do i know the name of the part but the piece where you push to rev it up on the motor, i wanna say the throttle. Anyways spin that screw on it and see it drops it some, I spun mine up cause it wasnt getting enough rpms at idle so it wouldnt start all the time. Just be careful, i turned mine a lil to much and it was idling at 2,000 haha but now its at like 1000 so its good.
Old May 13, 2008 | 12:39 PM
jsmarsh25's Avatar
jsmarsh25
+1 check your idle set screw. get it running and just turn it down EVER so SLIGHTLY. it's very touchy.
Old May 13, 2008 | 02:00 PM
GodAmGT00's Avatar
GodAmGT00
I don't know if it'd be the idle set screw since it's not a constant high RPM, more or less an intermittent RPM jump..
Does it do it more when it's up to operating temperature than when it's cold??
JT
Old May 13, 2008 | 02:12 PM
1sloblckgt's Avatar
1sloblckgt
I would give the idle adjustment screw a shot first. I had trouble with mine as well, and that fixed it for me. The IAC mode that you are referring to, makes your RPM's drop faster after a rev.
Old May 13, 2008 | 02:16 PM
avlon06's Avatar
avlon06
+1 for adjusting screw...mine was revving up to 5k and staying, then i adjusted the screw a bit, then finally took it straight out
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
Drastang
Sep 30, 2015 03:48 AM
MacSerio
Sep 27, 2015 01:05 PM
