failed mgw install
Old May 16, 2008 | 05:06 PM
jvog's Avatar
jvog
Default failed mgw install
Now most people run into trouble with getting the stock shifter to break loose.However, I didnt even make it that far. Three of the bolts holding the stock shifter came off easily, but the front right one refuses to come off. Its starting to get stripped so i just stopped. I am guessing I should try heating it up somehow but im not sure. Any ideas?
Old May 16, 2008 | 05:08 PM
jlong00's Avatar
jlong00
Default RE: failed mgw install
It shouldn't strip -- are you using the right size socket to remove the shifter bolts?
Old May 16, 2008 | 05:16 PM
jvog's Avatar
jvog
yea. its 13mm. the socket keeps popping off no matter what i do
Old May 16, 2008 | 05:38 PM
St4ng07's Avatar
St4ng07
If its stripped, take some valve grinding compound put it in the socket and it will be fine
Old May 16, 2008 | 05:52 PM
jvog's Avatar
jvog
its not completely stripped yet...maybe ill have to go buy some valve grinding compound although ive never heardof it.
Old May 16, 2008 | 05:56 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
you can try getting the next size smaller socket and hammering it onto the bolt then ratcheting it off...thats what ihad to do when i was rebuilding my dirtbike and it worked fine
Old May 16, 2008 | 05:58 PM
jvog's Avatar
jvog
i thought about that too but there isnt much room to be hammering
Old May 16, 2008 | 06:42 PM
Epic91GT's Avatar
Epic91GT
ORIGINAL: jvog
get creative in ur swings
Old May 16, 2008 | 07:17 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Here's what you need...[/align][/align]Also, in the future, make sure you use quality tools and that the socket is on the bolt squarely and solidly--and NO 12-point sockets, 6-point ONLY...[/align][/align]
Old May 16, 2008 | 09:08 PM
jvog's Avatar
jvog
i got it..i feel kinda dumb...the socket i was using had cracked...i got the first 3 off just fine im not sure what happened with the last one...its ok now. took it for a trial run after install. its definately a lot different than the stock shifter. the throws shorter but it seems to take more effort to shift into gear...is this normal?
