headers installed!
Old May 22, 2008 | 03:06 PM
2kStangGT08's Avatar
2kStangGT08
Default headers installed!
Got the lt's iand o/r h-pipe nstalled havent really got on it but i could feel the power ready 2 be unleashed.
Besides from my cel been on, i feel pressure when im at a stop light on the brake, and the idle is no long wut it use to be low and quiet, now it more rumbling and a bit higher. Finally, when i was turning intoa parking spacethe steering wheel got rough on me as i was coasting in.Is this normal or their are problems?
Old May 22, 2008 | 05:17 PM
MoKo_04GT's Avatar
MoKo_04GT
Default RE: headers installed!
[sm=ttiwwp.gif]
Old May 22, 2008 | 05:22 PM
2kStangGT08
how would u like me 2 post pics of wut im talking bout?
Old May 22, 2008 | 07:20 PM
nemo's Avatar
nemo
check the power steering level when your car is off after a min or so. You may just need more fluid.
Old May 22, 2008 | 10:24 PM
slow2kgt's Avatar
slow2kgt
The headers are most likely rubbing on the steering shaft
Old May 23, 2008 | 02:02 PM
2kStangGT08
if the headers are rubbing on the steering shaft what will need 2 b done?
Old May 23, 2008 | 02:24 PM
1sloblckgt's Avatar
1sloblckgt
The headers are probably rubbing the bolts on the steering shaft... You just need to grind it down a little bit... Then you should be fine.
Old May 23, 2008 | 04:11 PM
defconfire's Avatar
defconfire
Or you can just disconnect the motor mounts jack up the engine like 1/2 inch and shim them with about 1/4" of fender washers. it worked for me
Old May 23, 2008 | 11:31 PM
ColinGT's Avatar
ColinGT
I have headers and my car veers to the right, so like if i tak emy hands off it just takes it that way. Would that cause it to do that?
Old May 24, 2008 | 08:49 AM
2kStangGT08
ColinGT you probaly need an alingment.
