SPRING ADVICE
ORIGINAL: Lombardo05
thanks guys and 2k1gt will those springs fit a 2000 gt vert. im just curious b/c on am.com they make seperate versions for coupe and vert
http://www.americanmuscle.com/h-r-sp...ngs-96-04.html
i got those springs not the others. are you sure i need the CC plates?
Do you NEED them? No. You can lower your car without them and it won't blow up or anything. Are they recommended? Yes.
As you can see from the sig, my car is lowered quite a bit and I don't have new shocks/struts or C/C plates and i'm still running strong 40k miles after the install.
They allow for you Caster and Camber to be adjusted more... hints C/C plates.
When you're car gets lowered, it gets out of alignment, so the CC plates allow for more adjustment.
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
