changing differential cover
Old Jul 8, 2008 | 03:34 PM
ShinobiOfLegends's Avatar
ShinobiOfLegends
Default RE: changing differential cover
ORIGINAL: GodAmGT00
You're going to need different hardware, since the OEM bolts more than likely won't fit in those holes, if it's anything like the TA Girdle.. As long as you use some in the flavor of Grade 8 or Grade 10, and has a small enough head that will fit into those hole to be fairly flush, you should be good..
In fact, you could probably purchase TA Girdle Hardware, and be fine.. It may be a little pricey, but well worth it.. However, looking at the picture, it shows slots for the bearing cap studs. Those would ALSO need to be purchased, otherwise you'll have a serious loss of fluid, and you wouldn't get all of the benefits of a true differential girdle..
JT
yes, i'm aware that the stock hardware wont work with the girdle, its 1 inch think and the stock is paper thin....thats why i'm trying to find out where i can get the hardware. and if i cant get the hardware, oh well, i paid $10 for the girdle. so not a big loss.
Old Jul 8, 2008 | 04:06 PM
ShinobiOfLegends
well i just got off the phone with TA Performance and Kenne Bell. apparently the specs for the Kenne Bell Axle Girdle are almost identical to those of the TA 1806 LARGE. so i got the hardware kit for $30 plus shipping, so no worries. oh, and the hardware kits from summit racing and jegs are a joke. these girdles are too big for the hardware in their kits....
Old Jul 8, 2008 | 04:46 PM
1sloblckgt's Avatar
1sloblckgt
02Ninja put one onhis car... it wasn't KB though. I see you already found youre hardware, but if that doesnt work im sure he could help you out.
Old Jul 8, 2008 | 04:56 PM
ShinobiOfLegends
cool, thanx
Old Jul 8, 2008 | 08:22 PM
GodAmGT00's Avatar
GodAmGT00
Call me crazy, but I was able to put 3+ quarts of 75-140 and a halfa container of Friction modifier in my rear axle with the TA girdle... I also just did it with my Ranger(with the Ford 8.8" rear axle, an entire 3 quarts)... I don't believe the axles are any bigger on the Ranger than the Mustang.. In fact I believe they are almost the same width..
JT
Old Jul 8, 2008 | 08:51 PM
02 Ninja's Avatar
02 Ninja
inexpensive ($125) and a huge upgrade over what i had.
Old Jul 9, 2008 | 01:04 AM
Novanutcase's Avatar
Novanutcase
Bought a Trickflow! I'm happy with it!
John
mtgldr
Feb 3, 2024 09:00 PM
2007StangV6
Jan 28, 2016 06:09 PM
SilverStallion05
Sep 5, 2015 10:48 AM
aleit2013
Sep 4, 2015 11:58 AM
