fuel issue?
Old Jul 13, 2008 | 09:48 AM
ImpOnFire's Avatar
ImpOnFire
HRnB's Minion
Default fuel issue?
ok, heres the problem..
- check engine light for 'lean fuel' (no matter what grade i use)
- in nuetral, from idle it will not pass 4500 rpm, i could probably hold my foot on the gas all day and it will not pass it, unless i take my foot on/off the gas a couple times, then it will hesitantly
- when going from a complete stop (or actually any time while driving) it will jump easily up to about 4000 and very slowly climb higher and it almost feels like its gasping for air (or gas)
- when i shift, it takes a second to accelerate.. i dont really know how to explain it, but its almost like it has a hesitation before it grabs the gear..
-alsowhen i shift,(this has only happeneda couple times), itll start pulling like i either am out of gas or i went into a gear i shouldnt have (like i should have shifted to3rd and i went to 5th), and the two times it did it, thats what i thought i did, went into a high gear by mistake so i immediately downshifted and it was jerking like it didnt have any gas, but i floored it and after about 3 seconds rpms soared and so did the car
the boyfriend drove it and said the clutch needs replacing, but thats not my problem with the hesitation, he says its some kind of fuel issue but he doesnt know where to start, hes a vw/mini trucker guy, not a mustang guy.. so i thought i might try to get some advice before we start spending money replacing things that dont need to be
Old Jul 13, 2008 | 10:01 AM
black35th's Avatar
black35th
Default RE: fuel issue?
Have you changed your fuel filter? You might also need to clean your MAF sensor.
Old Jul 13, 2008 | 10:31 AM
ImpOnFire's Avatar
ImpOnFire
HRnB's Minion
yeah.. new fuel pump and filter.. sensor is a good idea though
Old Jul 13, 2008 | 10:44 AM
contentsunderpressur's Avatar
Yea, I say check the maf as well.
Old Jul 13, 2008 | 11:10 AM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
it really could be several issues. i know when i have a problem that cant be singled out right away.. i start with the easiest/cheapest and work from there.. best bet is to do what was already suggested, change the fuel filter and clean the maf sensor. if that doesnt help, id maybe check o2 sensors..
Old Jul 13, 2008 | 04:47 PM
ImpOnFire's Avatar
ImpOnFire
HRnB's Minion
so i cleaned that and i still have all the problems minus the wong rev past 4500..
this is probablya dumb question, but would that throw the lean fuel reading? on my 96 when my O2 was fking up i got a O2malfunction reading..
Old Jul 13, 2008 | 06:57 PM
Have you changed the fuel filter and fuel pump yet? Sounds like you may have a weak pump.
Old Jul 13, 2008 | 07:12 PM
2002GTAUTOVERT
an exhaust leak before or after the o2 sensor can cause it to lean out. a faulty sensor could do the same.. its not common.. but its not exactly rare. have you checked your pcv valve? all the lines running to the intake tubing both from the driver side bank and the throttle body?
EDIT: typo
Oct 26, 2015 05:01 PM
rocky321
Sep 15, 2015 10:00 AM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
