false advertisement ???
Take everything with a grain of salt, and do your own research before you rush into a purchase. Rule of thumb is companies that sell a product is not a proper place to research their product. Check forums for true research on the product.
A TB/Plm setup won't add 20rwhp....that's a joke. Any site will say that their product adds XXrwhp for a reason...
I'd like to see the dyno sheets where people actually did lose power by going with a 75mm setup.
TB/Plenum combo will only give gains like that on an FI vehicle. If you go with the combo that has the 70mm TB/Plenum you may see less than 5HP. If you go with the combo with the 75mm TB/Plenum you'll actually lose power. I've seen multiple dyno's on this site where guys lost power with the 75mm package. That is more geared towards FI, so on a stock engine & no FI the car will lose power.
If you must get this setup, go with the 70mm combo.
You're better off banking your money and getting cams or something else.
