i looked around a little myself and i found that people with similar part number say the same as myslow2002gt, thanks alot. i just want to make sure that i install them right, can't afford bent valves after buying all my parts, hahaha
You really can't install them wrong, unless you really are an idiot (not saying you are). Once you lay them in the cylinder head, you'll see what I mean. If you installed the wrong cam on the wrong head, the cam follower/cam lobe would not align correctly, it would be offset.
