The BIG Question!!!
Old Sep 15, 2008 | 09:27 PM
jfrazi35's Avatar
jfrazi35
Default The BIG Question!!!
Okay I have a 2001 GT and I am finally at the point where I need more power and have the money to do so!
I plan on doing a 4v swap (03-04 cobra heads), a nice set of cams, and a .10 over forged piston and rod kit, and all the necessary basic upgrades.
But my question is should i go with the supercharger, single mid size turbo, or two small turbos???
I am looking for anywhere from 500-800rwhp.
Help please.
Old Sep 15, 2008 | 09:32 PM
mustangman281's Avatar
mustangman281
Banned
Depends on how much money you have to spend.
Old Sep 15, 2008 | 09:45 PM
SVTeeshirt's Avatar
SVTeeshirt
90 mm turbo FTW
Old Sep 16, 2008 | 06:04 PM
jfrazi35's Avatar
jfrazi35
i will be looking to spend anywhere up to $10,000
suggestions?
Old Sep 16, 2008 | 06:07 PM
SUP3RSTANG's Avatar
SUP3RSTANG
suggestions?
just forge your shorblocks bottom end and slap a turbo on there. u can get 600~ hp our of ur 2v with heads and cams and seriously are u wanting more than that?
Old Sep 16, 2008 | 08:24 PM
teej281's Avatar
teej281
4.6L Section Moderator
i would just go with getting your motor bored out .30 over and blueprinted, get a forged rotating assembly(good for up to 1000hp), stage 3 heads and turbo cams, and a set of twin turbos from hellion. then you are going to need to get fuel system and driveline upgrades like clutch and stuff like that. and throw a new tranny in there as well. you are probably gonna spend more between 15k-20k before everything is said and done. especially if you have someone else do the work. but go 2v not 4v.
Old Sep 16, 2008 | 08:39 PM
BlackMage's Avatar
BlackMage
building that power you are going tro want to upgrade your whole driveline. trani, rear end, axles. and i would go tt
Old Sep 16, 2008 | 09:10 PM
mustangman281
Banned
suggestions?
Thats not gonna buy much. Maybe a forged shortblock, heads, cams, and vortech system with mild fuel system and let you make around 500-550rwhp.
If you want turbos get another $10,000 togather.
Old Sep 16, 2008 | 09:36 PM
Stevecooper's Avatar
Stevecooper
Isn't that ridiculous, you can't get much done with 10k these days.
Old Sep 16, 2008 | 11:17 PM
SUP3RSTANG's Avatar
SUP3RSTANG
for 10k i just got on MMRs site, got the 600hp shortblock, went to CMS got fox lake stage 2 heads and 2v blower cams, cam gears, valve springs, FULL suspension setup from AM+ 31 spline dif axels with driveshaft and flywheel.
for 1500 more u can build a vortech system buying everything separate and have a pretty mean ride id say u get a bit more than it seems
