Ticking
Could be a plethora of things.....head leak, spark plug leak from stripped spark plug hole (which was my issue), exhaust leak, timing chain, transmission.....the list goes on. You need to narrow it down more.
Btw, if it is the spark plug issue like I had, the kit to rebore a new hole and put a non helicoil, insert with a lip that actually locks into place is about $350 plus shipping. I bought the "Timesert" kit.
if your ticking is mostly at idle, like mine was, it very well could be failing/failed timing chain tensioners which causes the timing chain to slap against the plastic guide, its a tick/knock that doesn't quit sound like metal on metal.
I would take somewhere mine ticks every now and then but mine is the injectors these mod motors are some rattling sobs i know a guy who has a truck with a 5.4 and when you first start it up it rattles and knocks sounds like its about to fall apart but it has been doing this for 75,000 miles. does the ticking go away?
