Ticking
Old Oct 7, 2008 | 06:49 PM
00blackstang's Avatar
00blackstang
Default Ticking
My motor makes a ticking noise while at idle.... someone said loud fuel injectors, others said timeing chain rubbing..... does anyone else make a ticking noise?
Old Oct 7, 2008 | 06:51 PM
defconfire's Avatar
defconfire
I would guess its the timing chain. If the tensioner goes bad it will make a nice ticking noise.
Old Oct 7, 2008 | 07:13 PM
00blackstang
so when i install the cams, replace that.
Old Oct 7, 2008 | 07:23 PM
02 Ninja's Avatar
02 Ninja
Old Oct 7, 2008 | 07:28 PM
defconfire's Avatar
defconfire
That would definitely be a good thing to do while your in the engine. When are you doing cams?
Old Oct 7, 2008 | 07:33 PM
00blackstang
not till like december.... how can a stock motor with exhaust, be detonating running 93 octane
Old Oct 7, 2008 | 07:35 PM
defconfire's Avatar
defconfire
Does it only tick under load or is it noticeable at idle.
EDIT: I need to learn how to read Thanks WhiteFox
Old Oct 7, 2008 | 07:44 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
He said it ticks at idle...
My 4v with 12k miles ticks... Im pretty pissed off about it. Sounds almost like a manifold leak, but not as pronounced. Its most likely lash adjusters
Old Oct 7, 2008 | 08:36 PM
teej281's Avatar
teej281
4.6L Section Moderator
i think you might have an exhaust leak. thats what my ticking is...i hope.
Old Oct 7, 2008 | 09:24 PM
jvog's Avatar
jvog
my motor ticks too...not obnoxiously loud or anything..i read abot about it and from what i gathered a lot of 4.6s tick
