consindering stroking motor
Old Oct 15, 2008 | 08:48 PM
timi's Avatar
timi
Default consindering stroking motor
i'm thinking of modding the motor to include patriot stage 2 heads, comp stage 2 cams, valve springs, manley .20 over pistons and rings, rods.
is this a good combo? i want a kick *** sort of daily driver. and nos will come later.
how much more power will this give me? i make 258 rwhp now.
thanks
timi
Old Oct 15, 2008 | 10:53 PM
Zoie_daGT's Avatar
Zoie_daGT
I think that sounds like a sound combination. I would reconsider the patriot heads. I have heard just too many complaints about them. I would suggest, Foxlake(best IMHO) or MMR(did my heads). I see you have a camry but, are looking for a "kick *** sort of DD." If you really want to DD your car, I would choose the cams carefully. If you are looking for a fun car that is DEF streetable, I would go a bit wilder. Just my opinion though. Hope that help.
P.S. If you do internals, forged all the way, esp. if you thinking juice will come later.
Old Oct 15, 2008 | 11:10 PM
contentsunderpressur's Avatar
Forged internals is a great idea but don't stroke it. That's a waste of money.
Old Oct 15, 2008 | 11:39 PM
03mustgt's Avatar
03mustgt
+1, its not really worth the extra money.
Old Oct 16, 2008 | 12:23 AM
ZW99GT's Avatar
ZW99GT
If I had to do it all over again, I'd go with bigger cams. Check out the big Crower cams.
Old Oct 16, 2008 | 01:14 AM
2000AZ5.0GT's Avatar
2000AZ5.0GT
+1, it just adds to the stress on everything, not at all worth it
Old Oct 16, 2008 | 06:50 AM
BOSTANG's Avatar
BOSTANG
On that set up go with a 11cc piston. Forge everthing on the bottom in and the heads will come with springs.Dont forget about the headers. Should be around 315 hp.Then beef up the rear end with some 15 inch lite rim with skinny up front. Put some subframe conn. on too. Then if you want to loose some more weight do a k-member and aluminum driveshaft. Then spray the house down.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
