check this out! (mods im getting)
thats y i wraped without asking on here i have seen turbo dsms with wrapped headers on youtube. have u guys had experience with the hi heat coating that can b applied to the outside to seal it
Most of the guys that wrap their turbo headers are import guys where the headers don't go under the car.
Even with the coating the wrap gets gets soaked with water and stays traped in there rusting the pipes on cars where the headers go below the engine.
also still trying to figure out if this shifter gasket is needed
Shifter Gasket not needed but is nice to have. I made mine with gasket material and just traced around and cut out the needed holes.
And I know a few people have already told you this but I can't believe you put that header wrap on your car because you seen a few cars on youtube. Haven't you been around here long enough to know if the Import guys are doing it is the wrong thing to do.
If I read into your posts correctly you have no intention of taking the wrap off. I promises you will be sorry later.
im not doing it b/c of the imports im doing it to keep the engine compartment cooler and keep the exhaust gas temp up to keep the velocity of the exhaust up. would i be better off with the spray can hi temp stuff
