Understeer/Oversteer problems?
Old Nov 18, 2008 | 03:43 PM
jmac72187's Avatar
jmac72187
corner carver
Originally Posted by hpwrestler220
thanks for all of the info..
and i honestly have no clue how much camber i am running.. i can ask next time i get it aligned at the station..
im still trying to learn these things when the opportunities arise
I would run maybe -1* for the street. The tires may wear slightly quicker on the inside. I will be running at least -2* if not -3* next season for auto x.
Old Nov 18, 2008 | 04:06 PM
hpwrestler220's Avatar
hpwrestler220
ok. thanks for the input
Old Nov 18, 2008 | 07:35 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
I drive with 0* on the street, and a little over 3* in race trim.
OP, if you can achieve oversteer, go for it, that's what we strive for in auto-x
Old Nov 18, 2008 | 08:05 PM
hpwrestler220
i really do want to get out there and auto-x.. i most likely will come spring time..
this may be a dumb question.. but can somebody explain the definitions of both oversteer and understeer to me.. i made a thread about something i know very little about.. sorry guys. learn me
Old Nov 18, 2008 | 08:09 PM
SVTeeshirt's Avatar
SVTeeshirt
just go to the options menu, then click car specifications, then adjust to ur liking, the left **** will scroll it left and right.
Old Nov 18, 2008 | 08:35 PM
H0SS302's Avatar
H0SS302
Understeer is when the front tires loose grip so you cant turn as easy. over steer is when the *** end loses grip and u start to spin inward towards the apex
this is what iv gathered from forza 2 lol.. i dont know a true working def.
Old Nov 18, 2008 | 08:52 PM
2000AZ5.0GT
Understeer is when the car doesn't turn in as expected when turn the steering wheel. Neutral steering turns in just as much as you would expect when you turn the wheel, Oversteer is when the car turns more than you would expect.
But, hoss is sort of right. Understeer is created when the front end loses traction and doesn't turn in.
(best way I can explain it)
Old Nov 18, 2008 | 09:05 PM
H0SS302's Avatar
H0SS302
lol i just know that if my car doesnt turn in forza i need to go to the alignment page and do work. and then run a few laps. then fine tune in the differential panel. FWD cars are the worst with understeer
Old Nov 18, 2008 | 09:43 PM
hpwrestler220
hahaha hoss ur nuts.
thanks again guys! it makes sense
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
