replacing front rotors
Old Dec 28, 2008 | 04:16 PM
jaystang44's Avatar
jaystang44
Default replacing front rotors
ok i am trying to replace my front rotors..... do I need to remove the bearing to replace the rotors? I know how to take off the calibers and bracket..... then how do you take the bearings out I mean what tool to use or size socket??
thanks for any help
Old Dec 28, 2008 | 04:39 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Who told you anything about bearings?
Remove the caliper, unbolt the bracket. then pull the rotor off. If it doesnt jut fall off, when tap it with a hammer. There are no bearings or anything holding it on.
Old Dec 28, 2008 | 04:42 PM
jmstang66's Avatar
jmstang66
hmm never heard teh bearing thing..i too wanna know who told you that lol
Old Dec 28, 2008 | 04:48 PM
LynnBob Mustang's Avatar
LynnBob Mustang
There are no bearings in these rotors like the old school cars and rotors.
Lynn
Old Dec 28, 2008 | 04:54 PM
LynnBob Mustang
He may be like me and was thinking old school for a moment.
I had to stop and rethink that these had no bearings in the rotors also.
The old school rotors had bearings in the front and back thus letting the rotor spin on the spindle, when you took the castle nut off the spindle to get the rotor off "usually" the front bearing would pull right out of the rotor and the rear bearing could be taken out by placing the nut back on the spindle and pulling the rotor off by catching the nut and pulling the bearing out.
That is probably what he is thinking, or he has worked on other cars that have this same bearing set up.
Lynn
Old Dec 28, 2008 | 05:23 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Fox body Mustangs have the bearings in the rotors...Ford changed set-up on the '94 to current Mustangs...
Old Dec 28, 2008 | 05:24 PM
jaystang44's Avatar
jaystang44
well does the dust cap have to come off first before the rotors? once I took the calipers and bracket off there was the dust cap... I just figured since the dust cap was there then the bearings had to be taken off too plus I guess then my rotor was just stuck bc I puled and nothing came of....guess I should have used the hammer lol
But you guys are sure I dont need to touch the bearings and that after the caliper and backet are taken off, and possible the dust cap I couldnt see how the rotor could slide off with out taking it off, the rotor should just come right off?
Old Dec 28, 2008 | 06:10 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Dude, our cars have sealed hubs. The bearings dont just come out. Make sure the little metal clips are off the wheel studs (if they are there, there will be 2 of them) and just use a hammer and hit the rotor until it jars loose. This isnt hard
Old Dec 28, 2008 | 09:03 PM
vanquish's Avatar
vanquish
+1 if you aren't turning the rotors for reuse just bang them off with a hammer.
Old Dec 28, 2008 | 09:31 PM
945LSTANG's Avatar
945LSTANG
negative.
