New trickflow heads and cams or supercharge?
#41
i still think you should build a N/A 2v but its your car lol. Since my car is my DD i might buy some of these and hang on to them untill i get another car
#42
Yes we have 2 cam grinds that will be available also.
TFS-51802001
TRICK FLOW MODULAR FORD 4.6L/5.4L SOHC 2V CAMS
FMOD SOHC 2V CAMSHAFTS, PAIR, WITH 12mm CAM BOLTS & washers
Designed for street/strip NA applications, adds good low end torque, adds power throughout rpm range
FOR PI (performance improved) heads
Valve spring recommended TFS-2500500
RPM range 1500-5000
LIFT int./exh .550/.550
duration @ .050 int/exh 228/230
262/264 ADV. DURATION
112 LSA
TFS-51802002
Designed for street/strip NA & power adder applications, higher rpm capacity than stg1.
moves torque curve up in rpm range when compared to 51802001, adds power throughout rpm range
exhaust, gears, & cold air intake recommended, tune for max torque and power
must check for PTV clearance
RPM range 1800-6500+
LIFT int./exh .580/.580
duration @ .050 int/exh 234/234
275/275 ADV. DURATION
114 LSA
Priced 449.95/ pair
TFS-51802001
RPM range 1500-5000
112 LSA
TFS-51802002
114 LSA
Priced 449.95/ pair
Are these indeed for the TFS heads or the PI heads or both? I have a set of new Hitech stage 2's, .550"/.500" & 234*/230* on a 111*LSA-1* retarded. Now how would these react with the flow of the TFS heads? Some cammanufacturer that TF is working with should be able to punch numbers into the master cam program and with the flow come up with some numbers. I don't know if I should sell the Hitech's and go for the #2 cams or try the Hitechs!!??** I had a set of SHM #2730's which were .500/.500 & 230*/230* on a 113* LSA and the bottomend was not there, nada, couldn't spin a tire with 4.10's and a 3200rpm stall. Granted they were not degreed and needed shims under the lifters to make up for the small base circle.
How about it TFS or anyone here, what cam sounds best? The #2 TFS have 8* overlap at .050" lift while the Hitechs have 10*and I will have 11.5:1 compression. I need to get the dynamic compression down to a 9:1. How about durartion at .200" lift for cam #2?
Great prices but truly for which heads? I am going NA, compression listed, SVO intake-good to 6500rpm, forged and balanced internals in a Teksid block. UDP's and a DIY RAI/CAI.
Thanks for the extra infoon the cams.Mark
PS: How about the valve events in degrees at .050" please.Youknow, intake open/close, same for exhaust.THX again
#43
TFS-51802001
RPM range 1500-5000
112 LSA
TFS-51802002
114 LSA
Priced 449.95/ pair
TFS-51802001
RPM range 1500-5000
112 LSA
TFS-51802002
114 LSA
Priced 449.95/ pair
#44
I'll wait to see what numbers people are putting down to decide if the money is worth it for me...
i have stg 2 patriots... but if these are worth it... then i'll just say F it... and get the TF heads... lol
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
