Stock Plenum Rework
^+1. All of the aftermarket plenums are 3/4" to 7/8" taller than the OEM plenum, this allows a larger and more graceful bend in the "elbow" that cannot be accomplished on the OEM unit with any amount of grinding.
The OEM plenum has a 70.7 mm bore on the inlet, so there's no need to do anything to match it up with a 70 mm TB.
In the last, if you have limited funds, buy a plenum first. Look at Accufab's flow data here and you'll see that any aftermarket plenum (except C&L's), with the stock 65 mm TB, outflows the stock plenum with a 70 or 75 mm TB.
mungodrums
Sep 29, 2015 09:18 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
ccdguy
Sep 19, 2015 05:20 PM
