O2 Sensor Question...
Old Feb 11, 2009 | 03:11 PM
DeathRattle's Avatar
DeathRattle
Default O2 Sensor Question...
I was just wondering if anybody knows whether or not the upstream and downstream O2 sensors are the same...?? I ask because I just installed an X-pipe and I now realize that I put the rear sensors up front and the front sensors in the rear...if it doesn't matter where they go then I will leave them where they are, otherwise I will have to swap them around...any help is appreciated...
Old Feb 11, 2009 | 03:25 PM
vanquish's Avatar
vanquish
I think the 4 sensors themselves are the same.
Old Feb 11, 2009 | 08:02 PM
Brute03's Avatar
Brute03
well when you buy them, they have different part numbers so i'm going to assume that they're different
Old Feb 11, 2009 | 09:40 PM
vanquish's Avatar
vanquish
The front 2 sensors actually monitor the initial AFR while the back 2 verify that the converters are doing their job. So yes on one hand I could see that the sensors could be different.
Old Feb 11, 2009 | 09:48 PM
DeathRattle
hmm...sounds legit...
Old Feb 11, 2009 | 10:10 PM
vanquish's Avatar
vanquish
Did you replace the Bassani O/R H with the X? Does it sound better? I'm thinking of going X.
Old Feb 12, 2009 | 06:05 AM
DeathRattle
I always ran X-pipes but the last one was an H-pipe from Summit that I had to modify for the 5.4...it never souded right because it was all mangled so I can't really say how an H-pipe sounds...from looking at the 2 and comparing it looks like an X-pipe flows better...
Old Feb 12, 2009 | 08:03 AM
vanquish's Avatar
vanquish
I got you. Everyone uses an x with my mufflers so I'm guessing that's the best combo.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
