bad o2 sensor
Old Mar 22, 2009 | 01:26 PM
02stangdude's Avatar
02stangdude
Default bad o2 sensor
my friend and i hooked up his programer thinger to my car or whatever it is that reads the coads and its saying that i have a bad o2 sensor. should i not drive the car till i replace it and should i not spray it till i replace it?
Old Mar 22, 2009 | 01:42 PM
vanquish's Avatar
vanquish
you can drive it's not a big deal just buy a new sensor and put it in. If it's the rear o2 sensor you can drive and use nitrous I guess. If it's a front sensor I would change it asap because I think the front sensors report to the ECM for AFR changes.
Old Mar 22, 2009 | 01:44 PM
winterftbl's Avatar
winterftbl
I would just wait until you fix the problem before you spray. Why risk it?
Old Mar 24, 2009 | 05:26 AM
contentsunderpressur's Avatar
If your running a wet kit I say spray. A bad upstream o2 sensor makes the car run rich anyway.
Old Mar 24, 2009 | 10:03 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
What was the exact code or codes?
There are 4 O2 sensors, 2 in front of the cats that are used to adjust AFR in closed loop mode, and 2 downstream of the cats used to monitor the converters' efficiency. The code will reveal which of these is malfunctioning.
Also, many O2 sensor related codes are the result of a functioning sensor reporting some other problem--don't just start changing sensors becaused it mentions "O2 sensor" in the code description.
Once you get the codes you can look them up here to see possible causes and diagnostic tips...
Old Apr 21, 2009 | 10:27 AM
Deputy2B4Life's Avatar
Deputy2B4Life
ill second that... im having the same problem.. can a front o2 be switched with a rear o2? if so, that might help you trouble shoot...
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Dathan
Oct 5, 2015 05:52 AM
mltdwn12
Sep 23, 2015 08:54 AM
TfcCDR
Sep 14, 2015 12:08 PM
