Are these worth it?
I would not get them.
They will be an improvement over your stock ones for straight line launching, but NOT soo much for corners. In fact, they will be WORSE than stock in some ways.
Here is a copy/paste from earlier today:
There are some real fundamental issues with the Ford Sn95 quadra-bind suspension out back on your (our... but not mine ) rides. The LCA's/UCA's don't allow proper articulation of the rear axle so recommend the following items to address this:
'79~94 Adjustable Lower Control Arms
'79~94 Adjustable Upper Control Arms
Now.... these WILL add NVH (Noise Vibration Harshness) to your ride, but so will ANY good aftermarket LCA/UCA with poly/poly bushings. These have a spherical end which will allow the articulation (one wheel up in well, the other one down and out of well) of rear axle for MUCH better cornering of your ride. These will afford not only MUCH better "power to the ground" but ALSO better contact with the road surface when cornering on the street or track.
There is a much higher step to take if interested, so let me know.
HTH
Jazzer
HTH
Jazzer
^^^^ Only looking at these because i was told that they dont make them anymore and i have heard very good things about them from people on this forum i know OX runs them. Jazzer i have not heard real good things about upr seems people are 50/50 on there products.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
