My engine build
Old Apr 1, 2009 | 06:39 PM
mustangman03's Avatar
mustangman03
while were on machine shops what all should you get done to one, also would it be cheaper to buy a short block im getting ready to do the samething if you buy a new shortblock from mmr or somewhere like that do thye flycut their pistons also does anyone know anything about KT Engines in Charlotte NC i think i said it all.
Old Apr 1, 2009 | 06:48 PM
Quicktime_GT's Avatar
Quicktime_GT
are the teskid blocks stouter than a iron block?
Old Apr 1, 2009 | 07:11 PM
jvog's Avatar
jvog
Yea. Supposedly they hold 1500 hp
Old Apr 1, 2009 | 07:28 PM
teej281's Avatar
teej281
4.6L Section Moderator
Teksid blocks were made in Italy by the same engine manufacturer as Ferrari gets their motors from. They are waaaaay better than iron blocks.
Old Apr 2, 2009 | 01:25 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
Originally Posted by lizzyfan
Give Matt a call, he knows a few. Make sure you get pistons flycut
You don't need to flycut pistons if you go with CMS 2.5 blower cams.
Old Apr 2, 2009 | 01:29 PM
Fobra's Avatar
Fobra
Banned
never seen a real world differences other than nominal weight... and higher cost both to machine and purchase
Old Apr 2, 2009 | 03:09 PM
jvog's Avatar
jvog
Really? If that's the case than why would I pay for it if I don't have to?
Old Apr 2, 2009 | 03:31 PM
Furinox's Avatar
Furinox
Not sure if the 2v stuff is different when it comes to piston cc>compression ratios but if they are the same then those pistons have waaaay too much of a dish for running a centri blower. I went with 11 cc pistons which gave me a 9:1 comp ratio and I now wish I would have gone with a 9.5.
Old Apr 2, 2009 | 04:59 PM
jvog's Avatar
jvog
Yea 4v is different than 2v. My compression should be around 8.8 with my 2v heads.
Old Apr 3, 2009 | 08:51 AM
Furinox's Avatar
Furinox
Go at least 9.5 or your going to make quite a bit less power compared to what you did with a stock motor and same boost levels.
