Tuning Debate - Lets get it out on the table
If you do not care to learn to tune yourself then you may want to wait until you feel you've reached some perceived "tipping point", and have a custom tune done or do a mail-order tune. However you lose a lot of control that way and establish what to me is an annoying and unnecessary dependency.
2. If I load the car with the canned SCT tune with all the mods in SIG will it run right (including mid-length headers)
3. Is a mail order tune worth it?
[quote[
4. Am I running lean with exhaust and air mods? If so why can't I just add more fuel a little. I do not have a wideband.[/quote]
No. The intake air (all of it) is still being measured by the MAF and the PCM is adjusting fueling accordingly--there is nothing mechanical you can add or do to an n/a engine, short of very radical cams coupled with optimally selected LT headers, that can affect AFR to any great extent.
You are probably running a bit rich at WOT, by 0.5 to even 1.0 "AFR", as that's what most of the OEM strategies seem to do. As there is no knock sensor on the 2V engine Ford so set them up to go pretty rich at WOT to minimise warranty engine replacement regardless of what kind of swill gasoline was used and how hard it was beat upon. Which BTW is why even a dead stock GT will benefit from a good 93 octane tune.
There is no EPA certification, and therefore no constraints, for WOT operation.
Lets here the opinons.
